Activity Forums Adobe After Effects tumble letter displacement map… look inside help
  • tumble letter displacement map… look inside help
    Posted by Chris Smith on September 3, 2008 at 4:01 pm
    new comp letters Called “displace”
    “made another new comp” blockMask
    inside the comp is animated mask rectangle wich moves across the stage…….now this to create the letters to displace….a roll effect
    now im unsure were i should place the dispalecment map on the letters
    or the white rectangle….and which comp selection to choose…this effect is simple so im sure you one of you experts can help me please
    Chris Smith replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
