Activity Forums Apple Final Cut Pro Legacy Trying to update FCP 6.0.1 to 6.0.6
  • Trying to update FCP 6.0.1 to 6.0.6
    Posted by Gary Boland on October 3, 2011 at 8:17 pm
    About a year ago I purchased an intel I Mac to make a family video with fcp 6.0.1. I need to get it updated to 6.0.6. So I can edit other FCP projects started in 6.0.6 on my G5 mac. I have several FCP projects saved on my external HDs that I would like to edited with this faster intel Imac.
    FCP will not let me open projects started FCP 6.0.6 projects with FCP 6.0.1
    Several have sent links to pro applications folder updates, after updating them it still FCP 6.0.1
    So far, I cannot find the correct updates to get my FCP 6.0.1 to 6.0.6 anywhere.
    Any help?
    Gary
    Gary Boland replied 14 years, 11 months ago 3 Members · 3 Replies
  • John Fishback
    October 3, 2011 at 9:19 pm
    Have you tried exporting an XML from 6.0.1 and then opening it in 6.0.6? I don’t remember FCP6’s upgrade path. It’s been a while.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Jerry Hofmann
    October 4, 2011 at 1:51 pm
    You should be able to simply run software update and continue to run it until all is up to date. You cannot do this?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Gary Boland
    October 4, 2011 at 3:09 pm
    FCP was on the desk top and not in the applications folder. Once I put FCP it in the applications folder the updates went fine.
    How that happened, who knows?
