Activity Forums Audio Trying to throw together a basic ProTools system
  • Trying to throw together a basic ProTools system
    Posted by Paul Campbell on November 29, 2011 at 6:37 pm
    Greetings, herd. I’m presently running Adobe Audition 2.0 at home using a Delta 1010 card and i/o interface. My mixer has 8 sub-outs feeding the i/o inputs. For the most part, it’s worked well for me over the years, but it’s time to upgrade. That said, when I say “upgrade”, I’m talking as inexpensive as possible. I was thinking something like an iMac i5, a Digi 002 i/o, and ProTools 8. As ancient as this may sound, it’s still going to be a fine upgrade to what I’m using now. My question is: will this combination of hardware/software run well, or will there be any compatibility issues?
    I tried digging up specs on all the different ProTools versions out there, but it was seriously info overload. I’m hoping someone here can cut through all of that. Thanks a lot.
    Koffi alain Sessi replied 14 years, 9 months ago 2 Members · 4 Replies
  • Koffi alain Sessi
    November 29, 2011 at 7:47 pm
    Hello Paul,
    I work daily with two rigs that have the same configuration as the one you are planning to get. I am happy to report that I have not experienced any compatibility issues. These two systems have been in use for the last 3 years. I did the new iMac upgrade a couple of months back and the transition went smoothly.
    Alain Koffi Sessi
    Sound Designer
  • Paul Campbell
    November 29, 2011 at 7:59 pm
    Thanks, Alain! Great news. Time to start shopping. Hello Ebay! Take care.
  • Paul Campbell
    November 29, 2011 at 8:07 pm
    Alain, one more quick question. The Digi 002 can do 8 simultaneous line inputs, right? I know 1-4 are mic/line, but 5-8 should input fine at the same time, right?
  • Koffi alain Sessi
    November 29, 2011 at 9:44 pm
    You are correct Paul, inputs 5-8 should work fine with a line level signal. There are also the 8 ADAT channels and the 2 SPDIF channels in case you have a mic-pre that comes with better AD converters.
    Alain Koffi Sessi
    Sound Designer
