Activity Forums Adobe Illustrator Trying to ‘thin’ a compound path
  • Trying to ‘thin’ a compound path
    Posted by Tom Hawcroft on August 14, 2014 at 8:54 am
    Basically, I have used the image trace function of CS6 to convert a line drawing to compound paths, and I’m hoping:
    Is there any way to thin this compound path, like you might do with a stroke? Or am I better off using the pen tool to convert the drawing to standard paths?
    If I ‘release’ the compound path via the menu it fills the whole image with black. A white stroke on everything may give the appearance of thinning the black lines but I get the feeling it might cause problems later on. Any advice much appreciated.
    Cheers all!
    Tom Hawcroft replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
