Activity Forums Apple Final Cut Pro Legacy Trying to put HD to DVCAM with no luck
  • Trying to put HD to DVCAM with no luck
    Posted by Jay Burgess on August 27, 2012 at 3:59 pm
    My studio recently got a Canon 60D and I shot a project on it at 24p. To shoot 24p on the Canon it must be in HD at 1920×1080. I have edited and finished the project. I burned it to DVD for the client to preview and OK.
    The client has okayed it and I now need to send it out for close captioning. The company that does the CC needs it on DVCAM. That was not a problem for all my other projects as they were regular DV. With this new project I have run into issues of putting the project out to tape. The audio comes through all right but the video is just a frozen frame.
    I’m running my Mac Pro via firewire to an Aja I/O which is connected to my Sony DVCAM deck.
    Can someone help me, please?
    Rafael Amador replied 14 years ago 4 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    August 27, 2012 at 6:41 pm
    The AJA IO only does SD, from what I recall. The IOHD does HD So you need to be exporting from an SD sequence. And the other issue is 23.98fps to 29.97. Since the IO only does SD, does it add pulldown to the 23.98? I think it does…but that’s something you have to tell it to do.
    So you might have to put this into an SD 23.98 sequence, then export, adding pulldown to 29.97. As DVCAM doesn’t do 23.98.
    Shane
    Little Frog Post
  • Rafael Amador
    August 28, 2012 at 1:47 am
    [Shane Ross] “..And the other issue is 23.98fps to 29.97. Since the IO only does SD, does it add pulldown to the 23.98?”
    Sure. Otherwise you wouldn’t be able to monitor on any standard NTSC device.
    rafael
    http://www.nagavideo.com
  • Jay Burgess
    August 28, 2012 at 3:40 pm
    OK. I’ve got it in an SD sequence. How do I do the pulldown in order to put it out to DVCAM tape?
  • Jay Burgess
    August 28, 2012 at 9:06 pm
    Hello?
    Anybody here? Can someone tell me how to do the pulldown from 24p so I can spit this out onto DVCAM?
  • Todd Gillespie
    August 28, 2012 at 9:17 pm
    Shane already told you. Drop your HD sequence into a SD sequence.
    I would recommend just using a SD sequence at 29.97 and master to DVCAM. But it may not look the best as it would if you render through Compressor with the Frame Controls, but should be good enough for CC people.
    Todd
    Todd at UCSB
    Television Production
  • Shane Ross
    August 28, 2012 at 9:18 pm
    You do this in the AJA Control Panel. In the VIDEO OUT, you choose the frame rate you want to output to. The Frame BUffer will be on 23.98, then output to 29.97. Pulldown will be added.
    Shane
    Little Frog Post
  • Jay Burgess
    August 28, 2012 at 9:20 pm
    Thanks Shane. I’ll give it a try.
  • Jay Burgess
    August 30, 2012 at 4:08 pm
    I’ve looked at the Aja control panel and under format the only thing I can choose is output to 25 or 29.97. Unless I’ve misunderstood (highly likely) or have done something wrong, I’m guessing that the Aja can’t ingest the 24p because it doesn’t seem to be doing the pulldown (It’s an older Aja ProIO;not the newer HD). I can hear the audio come through just fine but the image is just one frozen frame.
    I may just be screwed unless I can come up with another work around. I guess shame on me for not thinking this process through all the way.
  • Rafael Amador
    August 31, 2012 at 5:11 am
    Are you not monitoring on ant external device (monitor or TV) attached to the AJA?
    Have a look to View > Video Playback.
    you should have an 23,98fps option. That’s the one you have to use there.
    Then the card will add the pulldown.
    [Jay Burgess] “at the Aja control panel and under format the only thing I can choose is output to 25 or 29.97. “
    That’s correct.
    The standar NTSC is always 29,97fps (Interlaced).
    Therefor the need to add the Pulldown to pack the 24p (23,98) in a 29,97fps signal.
    You see, when you play a Hollywood film DVD (p23,98fps), the DVD player adds the pulldown on the fly, so the TV set will get an standard NTSC signal (i29,97fps).
    If the DVD player wouldn’t add the pull down, average NTSC TV sets couldn’t play the movie.
    In your case the AJA will do the same.
    rafael
