Activity Forums Apple Final Cut Pro trying to open a fcp 10.0 project in fcp 10.2.3
  • trying to open a fcp 10.0 project in fcp 10.2.3
    Posted by David Palmieri on April 5, 2016 at 6:13 am
    I have gotten as far as having all the raw footage files open up in fcp 10.2.3 but the timeline project is nowhere to be seen. I am apparently not using the update function properly. Please help.
    This is what I have on the external drives.
    Drive 1:
    folder called “Final Cut Events”
    inside that is a folder called “Craft 15”
    inside that folder is 5 things:
    folder “Backups”
    file “CurrentVersion.fcpevent”
    folder “Original Media”
    folder “Render Files”
    folder “Transcoded Media”
    Drive 2:
    folder called”Craft 15 copy”
    in folder is 2 things:
    folder “Backups”
    file “CurrentVersion.fcpproject”
    when I do the update all in fcp 10.2.3 everything seems to show up in the new library except for the project (timeline)
    all the footage is there…just no timeline.
    *** I also tried creating a folder on drive 1 called ‘Final Cut Projects’ and placed the project file in there. fop is not finding any projects. just the event raw footage.***
    David
    Ronny Courtens replied 10 years, 5 months ago 4 Members · 5 Replies
  • Russ Haskell
    April 5, 2016 at 2:04 pm
    Is one of these drives your start-up? If it is, the Final Cut Projects folder needs to be in your Movies folder. Also, the entire sub-folder (Craft15 Copy) should be in the Final Cut Projects folder that you created – not just the project file.
    Russ
  • David Palmieri
    April 5, 2016 at 2:26 pm
    its not startup drive. to simplify, i created a new folder on drive 1 called “Final Cut Projects” and placed the project file in it. (so everything is now on 1 drive).
    The folder Craft 15 copy only has the project file in it and a folder called backups with one backup file of that project file in it. thats it.
  • Charlie Austin
    April 7, 2016 at 4:02 pm
    For pre 10.1 stuff, you should have 2 folders in the Folder you point X to for updating. A projects folder, and an events folder. Detail here, among other places…
    ~ My FCPX Babbling blog ~
    ~\”It is a poor craftsman who blames his tools.\”~
    ~\”The function you just attempted is not yet implemented\”~
  • David Palmieri
    April 7, 2016 at 4:21 pm
    yes, please see my last reply.
    i have done that.
    on the X drive i have 2 root directory folders with all the files in them:
    Final Cut Events and Final Cut Projects.
    its recognizing the stuff in the events folder. still not recognizing the project file.
  • Ronny Courtens
    April 7, 2016 at 8:27 pm
    Hi David,
    Let’s go through this step by step, just to make sure that everything updates correctly.
    On your X drive, create a new folder called “FCP X 10.0” and put the old Final Cut Projects and Final Cut Events folders inside this folder.
    So, inside “FCP X 10.0” you should have two folders:
    1. A folder called “Final Cut Events” with inside it a folder called “Craft 15”.
    In the “Craft 15” folder you need to have:
    – a “Backups” folder
    – a “CurrentVersion.fcpevent” file
    – an “Original Media” folder
    – a “Render Files” folder
    – a “Transcoded Media” folder
    2. A folder called “Final Cut Projects” with inside it a folder called “Craft 15”.
    In the “Craft 15” folder You need to have:
    – a “CurrentVersion.fcpproject” file
    If that’s correct, launch FCP X and select File > Update Projects and Events”.
    The Update window will open. In the Update window, click the Locate button.
    A Finder window will open. In the Finder window, go to your X drive and select the “FCP X 10.0” folder, then press the Update button.
    FCP X will create a new Library from the old Final Cut Projects and Final Cut Events folders.
    Under the Library icon you see a folder called “Smart Collections”. Click on the little triangle to disclose the contents of this folder. Inside it you will see a Smart Collection called “Projects”. Select it. Do you see any projects in the Browser now?
    – Ronny
