Activity Forums Adobe After Effects Trying to make a dotted line appear as a parabol on a globe and make both rotate (y rotate) together
  • Trying to make a dotted line appear as a parabol on a globe and make both rotate (y rotate) together
    Posted by Ralph Choueiri on October 2, 2011 at 9:35 pm
    hi, i have created a globe, ( cc sphere) and a dotted line with a shape layer made the line parabolic as if its rising in the air from the globe from point A to point b. my problem is i want to rotate the globe on a 3d layer( y rotate) and i want the dotted line to rotate with it keeping point a and b.
    your help is highly appreciated, i have a delivery to make and i’m stuck there…
    Constanti Dinu replied 12 years, 3 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    October 4, 2011 at 3:58 pm
    Just saw this – hope I can still help:
    CC Sphere is not a 3d layer. It can be linked using expressions to a 3d Null. On the Y axis it should be:
    -(thisComp.layer(“Null 1”).transform.yRotation)
    since CC Sphere rotates on the Y the opposite direction. You can then link your 3d layer of a dotted line to the Null and animate. When the line should go behind the sphere you need to mask that out.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Ralph Choueiri
    October 5, 2011 at 8:34 am
    thanks ted, that got me pretty close, to have a better idea of the globe i m trying to create, check this link;
    https://www.istockphoto.com/stock-video-6844637-world-network.php?st=3d4b6e4
    i don’t really know if this was made with AE… but anyways that’s what i m trying to do… and thanks again
  • Constanti Dinu
    May 31, 2014 at 12:16 pm
    Any chance you solved the problem? i’m struggling here trying to get the same result as in the link
