Activity › Forums › Apple Motion › Trying to learn how to reveal lines as if they are being drawn.
Posted by Jaime Martinez on July 13, 2006 at 4:19 pmAnyone out there familiar with this technique? It seems to be pretty popular in television these days.
Mark Spencer replied 20 years, 2 months ago 5 Members · 5 Replies -
Chris Cleaver
July 14, 2006 at 12:35 pmThere’s a great tutorial on drawing lines on maps, for instance, at this site:
https://www.motionsmarts.com/tutorials/drawinglines/drawinglines1.html
Is this what you’re looking for?
Chris
Michelle Weiss
July 17, 2006 at 4:50 amHeya,
Sorry to hijack the post, but I’m looking for a similar solution. The above tutorial is great, but what if you want to draw something more complex? After Effects write on filter is great as you can import paths that you would like to follow, so you can have text writing on for example. I can’t seem to find anything in the Motion manual for importing paths, nor a way to “paint” a mask in the same way AE’s write-on works.
Any other suggestions?
Shell -
Doyle Rockwell
July 18, 2006 at 7:04 pmHeya,
The replicator line-drawing method can be used as a general write-on tool. Basically, take the image/text/whatever that you want to use as a template and use it as the source for an image mask on the replicator. The replicator draws on the “fill” and the mask cleans it up.
An example can be found here: https://homepage.mac.com/specialcase/writeon.html
Michelle Weiss
July 19, 2006 at 12:48 amCool
Yeah, that works. I hadn’t discovered the image mask tool yet, really helpful! Slowly but surely….
Thanks specialcase!
Mark Spencer
July 21, 2006 at 4:05 amSpecial Case, any possiblity you could post a version of the project that would open in 2.0?
Mark—
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, FCP, DVDSP and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press
https://www.applemotion.net
