Activity Forums Apple Final Cut Pro Legacy Trying to import MP4 with Linear PCM codec into FCP7
  • Trying to import MP4 with Linear PCM codec into FCP7
    Posted by Molly Sharp on February 24, 2013 at 12:01 am
    I’ve tried downloading the Sony Log and Transfer plug in, but I cannot figure out if that helps once the file is already in the MP4 state. The MP4 was provided by a client, so there is no way to get the native file.
    Thank you.
    Rafael Amador replied 13 years, 6 months ago 3 Members · 2 Replies
  • Brian Stokes
    February 24, 2013 at 12:33 am
    Use free applications like MPEG Streamclip or 5DtoRGB to convert it to a file you like for example Apple ProRes, etc.
    Then bring it into FCP.
    iStoker.net
  • Rafael Amador
    February 24, 2013 at 2:35 am
    [Molly Sharp] “I’ve tried downloading the Sony Log and Transfer plug in, but I cannot figure out if that helps once the file is already in the MP4 state. The MP4 was provided by a client, so there is no way to get the native file.”
    Are you talking about MP4 coming from XDCAM cameras?
    You can’t use L&T without the full card structure.
    If you have just the MP4 you need to rebuild the file/folders structure using the SONY Clip Browser. Then you can run L&T/
    The other solution is to use Calibrated plugin:
    https://www.calibratedsoftware.com/MP4EXImport_Mac.asp
    rafael
