Activity Forums Adobe Premiere Pro Trying to Edit AVCHD on CS6 and playback is choppy after 10 seconds…
  • Trying to Edit AVCHD on CS6 and playback is choppy after 10 seconds…
    Posted by Yannis Mendez on July 15, 2012 at 2:45 am
    Hi all
    This is my first post on CC.net so here goes:
    Trying to edit AVCHD 1080/50p .mts footage shot on a Panasonic SD90 and after around 10 seconds of playback it starts to get ridiculously choppy.
    Editing on a 2ghz iMac with intel dual core 2 with 4gb of Ram. I’m guessing this is probably due to my machine not being up to the task so wanted to know what is the easiest way to edit these files via proxy and then replace them with the originals to keep quality high?
    I have looked into Speedgrade proxy but they don’t allow you to import .mts files.
    Ive just changed from FCP back to CS6 because of the wide use of formats and really didn’t want to have to convert files back and forth, wouldn’t mind changing playback quality to 1/8 or even 1/16 to see if this helps, but cs6 won’t let me get lower then 1/4 playback does anyone know why?
    Thanks in advance.
    Yannis
    Yannis Mendez replied 13 years, 10 months ago 2 Members · 2 Replies
  • Itamar Kool
    July 15, 2012 at 2:04 pm
    I am working on an 8 core Mac with 12 gigs of RAM and my AVCHD timeline also is quite choppy. Audio works on and off, mostly not sync. Very annoying
    Kool En De Anderen
    MAC Pro 8 core/OS 10.6.8/BMD Intensity Pro/Apple FCS 3/Adobe Production Premium CS6
    http://www.koolendeanderen.nl
  • Yannis Mendez
    July 15, 2012 at 2:13 pm
    I think I might have found a work around, its not ideal, but as the final film will be around 10 min it should work. I place all my files into a sequence (1080p/50) I call RENDER then render the entire sequence, it turns from Yellow to Green as adobe creates preview files which seem to work fine. Then I use the RENDER sequence as I would my bin and copy/edit files easier.
    I do wish adobe had managed to do this once the files are imported.
    Regards
    Yannis
