Activity › Forums › Adobe After Effects › Trying to create moving glowing spheres with trailers
Posted by Miro Segura on October 11, 2011 at 8:17 pmHello,
I’m trying to create moving glowing spheres with trailers. Tried Echo space but want to see if there are any other solutions/plugins. I want to create a similar look to the link below that I have attached. Any help would be great!
https://www.youtube.com/watch?v=ol51xT8kTHI
Many thanks!!
Miro
Miro Segura replied 14 years, 10 months ago 4 Members · 5 Replies -
John Fishback
October 11, 2011 at 9:09 pmCheckout this link to VideoCopilot’s free tutorials. You’ll get good ideas there.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ben G unguren
October 12, 2011 at 3:14 amWhat’s not working with Echo? As long as you get your precomps right, Echo seems like the perfect filter for this look.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Miro Segura
October 12, 2011 at 3:38 amI think I’m struggling to make the spheres behave the way they look like on the video.
Walter Soyka
October 12, 2011 at 8:51 pmThe trails don’t move — they pop up in place after the leader passes their position. In other words, you don’t want the trails to actually follow the animation of the leader.
I’d animate the leader, then use its animated position to drive the emitter in a particle system. The particles should have neither velocity from the emitter nor velocity from motion, and you their decay can be controlled with the particles’ opacity over life setting.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Miro Segura
October 12, 2011 at 11:46 pmThanks all for your suggestions, will try the Particle Emitter
Miro
