Activity Forums Apple Final Cut Pro Legacy Trying to create an mpeg2 fie with CC
  • Trying to create an mpeg2 fie with CC
    Posted by Chase Maser on December 3, 2010 at 5:49 pm
    One of are half hour tv shows was picked up by another distributor. We would usually just send them a beta tape with the episode, but they wanted the show as an mpeg2 file. All i want to do is create an mpep2 file that is 720×486. I tried running the show through compressor, but it turns the 720×486 to 640×480. I’m probably looking over something.
    Chase Maser
    Editor
    http://www.he-tv.com
    Rafael Amador replied 15 years, 9 months ago 3 Members · 4 Replies
  • Chris Tompkins
    December 3, 2010 at 6:40 pm
    A mpeg2 SD clip outta compressor should yield a 720X480 clip.
    Are you viewing the clip in QT?
    Chris Tompkins
    Video Atlanta LLC
  • Chase Maser
    December 3, 2010 at 6:46 pm
    No the 720×486 is on my FCP timeline. We usually output to beta tape.
    Chase Maser
    Editor
  • Chris Tompkins
    December 3, 2010 at 6:53 pm
    Where are you viewing the 640X480? Quicktime does not always show the true pixels.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    December 4, 2010 at 11:23 am
    [Chase Maser] ” All i want to do is create an mpep2 file that is 720×486. I”
    Hi Chase,
    I don’t think that you can do that kind of MPEG-2 because that size is not standard.
    Ask your customers if an IMX would be OK.
    IMX is MPEG-2 with PCM audio and supports that size (720×486).
    You can do it with FC, Compressor, MPGstreamclip or even QT.
    rafael
    http://www.nagavideo.com
