Activity › Forums › Adobe After Effects › Trying to create an effect of lines being drawn by fingers?
  • Trying to create an effect of lines being drawn by fingers?
    Posted by Dillon Smith on September 2, 2015 at 5:50 pm
    I have a small clip I am working on for a music video. I am COMPLETELY new to AE and similar programs with only a few projects under my belt. I’m having a hard time researching the particular effect I am looking for because I have no idea what it would be called. So i’ve uploaded the clip to my Youtube channel in hopes that one of you can look at it and tell me which effect I need and possibly give me a small set of instructions if it isn’t too much to ask.
    Here’s the clip: https://youtu.be/co5NLPJ4ndU
    Here’s what I want to do. At the 0:06 second mark he draws a TV with his fingers. I am trying to make it seem as if he is drawing a tv frame (Bold lines) that follow the timing of his fingers. After the lines are drawn I plan on adding a small “static” clip inside the square to complete the “tv”. I have tried using the drawing tool to make a path and then using the stroke effect to follow the path. But I have had little luck so far. I hope to hear from you guys. Thanks.
    John Cuevas replied 11 years ago 3 Members · 2 Replies
  • Bre Snitchler
    September 3, 2015 at 8:11 am
    Couldn’t click the link for some reason so I have no frame of reference.
    I’m currently working on a project that requires a similar effect and I’m using the stroke effect. Is this not the look you’re going for, or are you having issues applying the effect?
  • John Cuevas
    September 3, 2015 at 1:35 pm
    You might want to mention that for people at work, they probably should turn the volume down on their computers as there is some NSFW language in that video.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
