Activity Forums Adobe After Effects Trying to asynchronously Scale a circles outline
  • Trying to asynchronously Scale a circles outline
    Posted by Marten Zander on May 5, 2016 at 11:45 am
    Hey,
    I am just trying to scale the outline of a circle but asynchronously. This means I don’t want to scale all parts of the outline at once with the same amount. I actually want to make it like a radial wipe reveal.
    I want the outline to scale from 0% to 100% in a radial manner. I hope you know what I mean because I couldn’t find an example video right now.
    What I tried so far:
    I created a Luma Matte using two Layers (black & White). On the top Layer I used the simple radial wipe effect to actually create a heightmap displaying the right information for my scale animation.
    I than created an adjustment layer on top of my outline layer with a simple transform effect and my scale animation set up. I than used my heightmap to be a luma matte for my adjustment layer.
    But somehow that’s not working out.
    Is there any other way to achieve what I am looking for?
    I hope oyu guys got me right. Thanks in Advance!
    Screen Designer/ Front-End Developer at Slim Interactive GmbH
    http//www.weareslim.de
    Wallace Adrian d’alessio replied 10 years, 4 months ago 7 Members · 6 Replies
  • Walter Soyka
    May 5, 2016 at 1:48 pm
    Could you share a couple of quick sketches that visually show the progression you want?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kalleheikki Kannisto
    May 5, 2016 at 2:08 pm
    If I understand the objective correctly, you could probably do it in the following fashion:
    1) Create a straight line that thickens in a wedge shape and stays at that final size. Sort of like and elongated pencil outline.
    2) Animate it in from outside the comp to the final stage of a fully thick line. Y-position close to the top edge of the comp.
    3) Precomp and add polar coordinates on the precomp.
  • Tudor “ted” jelescu
    May 5, 2016 at 2:38 pm
    Just like Walter I have a hard time visualizing what you’re after – storyboard the animation and post it
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Richard Herd
    May 5, 2016 at 7:21 pm
    Funny! I just did something very similar (if I understand what you mean)! Here’s what I did:
    I used a shape layer and made 8 “boxes” that line up exactly to form an entire line across the screen. Then I animated each box up and/or down.
    Precomp that.
    Apply the polar coordinates effect to the precomp.
  • Eric Santiago
    May 5, 2016 at 7:40 pm
    [Marten Zander] “I am just trying to scale the outline of a circle but asynchronously.”
    Im not sure but would the Effect > Generate > Ellipse help?
  • Wallace Adrian d’alessio
    May 7, 2016 at 12:49 am
