Activity › Forums › Adobe After Effects Expressions › Trying to animate only y possition with an expression
Posted by Nick Esposito on June 10, 2006 at 5:04 pmHi,
I’m trying to animate the y motion of a layer with an expression that references audio keyframes.
My problem is that I can’t isolate only the y axis with the whip. Any ideas?Cheers!
Nick EspoPatrick Oneill replied 8 years, 6 months ago 6 Members · 12 Replies -
Mylenium
June 10, 2006 at 5:42 pmAssuming you used the “Audio to Keyframes” keyframe assistant, this will work:
[position[0],thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”)]
Mylenium
[Pour Myl
Dan Ebberts
June 10, 2006 at 5:59 pmIf you just want to offset your y position with the audio amplitude, you probably want something like this:
multiplier = -5;
audio = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
value + [0,audio*multiplier]Adjust multiplier to set the direction (minus is up) and amplitude of movement.
Dan
Nick Esposito
June 10, 2006 at 7:24 pmThanks for you answers, I did use convert audio to keyframes.
My problem is I can’t animate only the y position.
When I add the expression it effects both the x & yHow would I make the expression target only the y axis of movement?
Cheers!
Nick Espo -
Dan Ebberts
June 10, 2006 at 7:53 pmWhich expression are you talking about? Either of the ones suggested here should only affect y.
Dan
Nick Esposito
June 10, 2006 at 8:03 pmThanks guys for your time!
I used this one:
[position[0],thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”)]For my own edification. How would I change this expression and make it effect the y axis?
Cheers!
Nick Espo -
Dan Ebberts
June 10, 2006 at 8:16 pmThat expression should move your layer to the top of the comp (without changing the x position) and bounce it downward in response to the audio (i.e. on the y axis only). Is that not what it does for you?
Dan
Nick Esposito
June 10, 2006 at 8:28 pmIt works great. Thanks for saving the day. But why does it work?
Like in:
[position[0],thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”)]Is it [position[0] that isolates the y axis? How would I isolate the x axis?
Thanks!!!!
Cheers!
Nick Espo -
Dan Ebberts
June 10, 2006 at 8:35 pmposition[0] is the pre-expression x value (static value + effect of any keyframes). So this expression:
says – use the pre-expression x value for x and the audio amplitude for y. To keep the original y value and affect x only, you’d do it like this:
[thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”),position[1]]
Dan
Nick Esposito
June 10, 2006 at 8:41 pmOK. I’ll try to understand that.
Thanks for the help!
It works great.Cheers!
Nick Espo -
Steve Roberts
June 10, 2006 at 9:05 pmThe old long-form way of writing “position” may be instructive:
{position[0],position[1],position[2]]
… means “x position, y position, z position” for a 3D-enabled solid. If you write that (or just the two-dimensional version) then highlight “position[1]” and pickwhip to it, you’re in business.
There are other ways. Search the COW for “Ebberts” as author, and copy the posts to a word processor. Dan’s posts are worth saving, and he never wastes a post.
