Activity Forums Adobe After Effects trying to animate Bubbles or Particles alone a path in a tube??
  • trying to animate Bubbles or Particles alone a path in a tube??
    Posted by Mark Linthicum on January 10, 2014 at 5:24 pm
    Hi All,
    I know I have seen this done before, i am trying to animate Bubbles or Particles alone a path (in a tube),
    The particles need to move along a curved path and not go outside the constrains of a the tube.
    If anyone can point me in the direction of how to do this with the stock AE plugins or if it is not possible what 3rd party plugs i need it would be greatly appreciated.
    Thanks Mark
    Thanks, Mark
    Roland R. kahlenberg replied 12 years, 8 months ago 3 Members · 3 Replies
  • Bobby Yarsulik
    January 10, 2014 at 6:39 pm
    Was doing some searching because I don’t personally know how to achieve this, but it looks like someone may have included a project file in this post on Video Copilot that may achieve what you are looking for!
    https://www.videocopilot.net/forum/viewtopic.php?f=4&t=40384
    edit: Although it looks like he is using particular, so I’m not sure if that is required or if you can use the stock particle plugins or not!
  • Mark Linthicum
    January 11, 2014 at 8:20 pm
    Thanks Bobby Yarsulik!
    Thanks, Mark
  • Roland R. kahlenberg
    January 12, 2014 at 4:58 am
    AE’s built-in Foam plugin will do this. More info here – https://helpx.adobe.com/en/after-effects/using/simulation-effects.html#foam_effect.
    Pay particular attention to the use of a Flow Map which dictates the confines of particles created by Foam.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
