Activity Forums Adobe After Effects Trying to achieve this effect?!
  • Trying to achieve this effect?!
    Posted by Chaernon Adrian on October 30, 2016 at 12:38 pm
    I`m trying to make something similar, but HAVE NO IDEA whatsoever how this is done, so I can`t really go on YouTube and search for the effect because I don`t know how it`s called.
    Can someone please elaborate on this effect that`s happening in this video from 0:35 to 0:55 –>
    https://www.youtube.com/watch?v=GIaVtBdHsa8
    How is this called? How is it actually done?
    Tero Ahlfors replied 9 years, 10 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    October 30, 2016 at 1:00 pm
    Not sure if this is how it’s done, but you can achieve this effect if you take several frames from a shot where there is camera movement and morph in between them.
    So let’s say you pick the following frames from a second of footage (25 fps example):
    1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
    You would morph from 1 to10 in 25 frames, then from 10 to 1, again from 1 to 10 and then 10 to 18. Then 18 to 24, 24 to 18 , 18 to 24, 24 to the next frame you pick up. You may need to play around a bit until figure out the frames you pick and the amount of frames in which the morph happens so that you can match the beat.
    I hope it makes sense to you.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Tero Ahlfors
    October 30, 2016 at 7:40 pm
    You have two cameras shooting simultaneously but not exactly the same composition. Then you morph between the cameras. IMO this looks really dumb.
