Activity › Forums › Adobe After Effects › Trying to achieve a certain effect…
  • Trying to achieve a certain effect…
    Posted by Rob Mason on October 3, 2018 at 5:48 pm
    Hopefully you guys can help me because I am stuck. I am trying to achieve a “connected network” look where the particles are all connected with lines to each other, and not just a single source. I’ve included a picture as a reference of the style I am going for, but I am imaging some 3D depth as well…
    I know Plexus might be better than using Trapcode Particular, but I still want to have the ability to animate the individual lines & perhaps even the individual particles themselves.
    Let me know if you think this is beyond Particular’s capabilities.
    Appreciate your guys help.
    Rob Mason replied 7 years, 11 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    October 5, 2018 at 1:18 pm
    Particular will not give you those connecting lines, so it is pretty much out of question.
    With Plexus you can always use a second (third, fourth…) layer with specific points on them if you want added flexibility. You can control every single point with a null object, if need be, so if you want lines between specific points, you can put just those points on a separate Plexus layer or precomp with just those nulls.
    Alternatively, there’s a connect layers plugin, but I would still suggest Plexus for anything even slightly complex.
    Senior Graphic Designer
  • Rob Mason
    October 13, 2018 at 1:29 pm
    Appreciate your suggestions!
    Sorry for the late reply.
