Activity › Forums › Creative Community Conversations › trying out compound clips
  • Tony Silanskas
    July 13, 2011 at 7:37 am
    The only success I have had (besides manually cutting each clip) is to the Compound Clip method. Agreed we need an easy way to do this. Also, I couldn’t tell from you video if the Compound Clip method worked on not for you. Are you having problems with Compound Clip blades not going through all the clips? I haven’t had this problem yet.
    tony
    http://www.HungryCliff.com
