Activity › Forums › Adobe Premiere Pro › “true” 16:9 looks crazy in Premiere Pro 2.0!
  • “true” 16:9 looks crazy in Premiere Pro 2.0!
    Posted by Marc Brak on September 16, 2007 at 6:04 am
    I’ll probably expose myself as an absolute beginner asking this, but i have a problem importing some “true 16:9” footage into Premiere Pro 2.0.
    Everything looks fine in Premiere pro 1.5 (it tells me it’s 720×576, aspect ratio 1.422). Exported a tryout clip, everything seems fine.
    But Premiere 2.0 tells me the footage is actually 1024×576, aspect ratio 1.4, and displays it grossly stretched. In order to make it fit the monitor, i’d have to scale the width down to 71%.
    So, what gives? I have a sneaking feeling Premiere 2.0 somehow just “misinterprets” the footage, but i can’t see why…
    Darren Edwards replied 19 years ago 4 Members · 4 Replies
  • Blast1
    September 16, 2007 at 11:43 am
    When you say true widescreen do you mean 720×576 1.4 or 1024×576 square?
  • Vince Becquiot
    September 16, 2007 at 2:26 pm
    I have a feeling it’s interpreted as square too. Right click on the footage > Interpret Footage.
    Vince
  • Marc Brak
    September 17, 2007 at 9:27 am
    The cow has done it again! I would never have found this out myself, but is did the trick!
    Thanks a lot guys 🙂
  • Darren Edwards
    September 17, 2007 at 12:54 pm
    Be careful with interpretation presets when it comes to
    After Effects, too. AE will normally default to an interlaced
    ‘Lower (or Upper) Fields’ first for any imported footage –
    which is fine if you’re working with interlaced, but not
    needed if you’re working with progressive. If you’re working
    with an uncustomised copy of AE, and progressive footage,
    always give your imported footage a right-click/interpret
    footage check before working with it. 🙂
    Darren.
    x-gf.com
