Activity Forums DaVinci Resolve True 10-bit per channel RGB in laptop panel
  • True 10-bit per channel RGB in laptop panel
    Posted by Robert Casper on June 23, 2020 at 1:00 am
    Is there a laptop, COTS or Custom Build, available from any manufacturer with a panel (display) that has “True” 10 bit color (Not 8+2 Frame Rate Control or Dithering)? Other desired specs seem achievable. Thanks.
    Robert Casper replied 6 years, 2 months ago 3 Members · 4 Replies
  • Marc Wielage
    June 24, 2020 at 1:06 pm
    I don’t think there are.
  • Eric Santiago
    June 27, 2020 at 7:48 pm
    That would be an odd option since the GUI would take up 60% of the screen.
    Even at full screen, there is no benefit IMHO.
  • Robert Casper
    June 28, 2020 at 6:02 pm
    Thank you.
  • Robert Casper
    June 28, 2020 at 6:09 pm
    Dear Eric, You appear to have a grasp on this. While I know the term GUI, I don’t understand. You may help me drop another question I have posed to the manufacturers, if a 10 bit laptop panel is in future generations. Can you elaborate on why your answer makes a difference. After, that I think I will be able to get past this. Than you very much.
