Activity Forums Apple Final Cut Pro Legacy Troubles from FC to MPEGStreamclip with HD
  • Troubles from FC to MPEGStreamclip with HD
    Posted by Paolo Drusi on March 24, 2013 at 5:02 pm
    Hello,
    I’ve shot a video with the new Canon HF G25 in format MTS 1920 × 1080 25fps, converted it using ClipWrap into .mov format as follow
    H.264, 1440 x 1080 (1920 x 1080), Millions
    24-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
    Normal Size: 1920 x 1080 pixels
    Current Size: 1920 x 1080 pixels (Actual)
    I’ve put this into FC in a new sequence format as follow
    Compressor: H.264
    Pixel aspect: HD 1440 x 1080
    Frame Size: 1440 x 1080
    25fps
    When I export it as .mov it looks fine, great quality. When I compress it using MPEGStreamclip into mp4 quality is not as good. I’ve incorporated some slides that don’t look as sharp as in the mov before mp4 compression and some lines look jerky.
    Settings in MPEGStreamclip are
    Compression: H.264
    No interlace/deinterlace selected
    Any clues why the mov out of FC looks great and the mp4 from streamclip looks jerky?
    Thank you very much for any help
    Paolo
    Paolo Drusi replied 13 years, 5 months ago 3 Members · 3 Replies
  • Spencer Averick
    March 24, 2013 at 6:52 pm
    When you export from FCP you are just exporting as is without compression, no quality loss.
    When you export from streamclip you are compressing into a smaller file, with quality loss.
    Check your data rate when exporting from streamclip, this will control the quality/file size of your compressed file.
    Fyi- not a good idea to edit with h264 files in FCP. Always convert your footage from that camera to ProRes LT before editing in FCP.
  • Shane Ross
    March 24, 2013 at 7:10 pm
    Your problems started when you converted to H.264 and tried to edit that in FCP. FCP doesn’t like it, and any host of issues will crop up. Gotta convert to ProRes before editing.
    Shane
    Little Frog Post
  • Paolo Drusi
    March 24, 2013 at 9:35 pm
    Yes I’ve read about this issue and forgot on the rush of production time. I’ve tried to export to mp4 from QT instead of mpegstreamclip and the quality is much better, I’ll give it a go this way.
    Thanks a lot guys!
    p
