Activity › Forums › AJA Video Systems › Trouble with Video Playback from AE
  • Trouble with Video Playback from AE
    Posted by Michael Nikitin on August 4, 2009 at 9:04 pm
    Hi guys,
    I’m having trouble with playback from AE. Perhaps someone will have pointers regarding what could be the issue.
    I’m running Aja IoHD with latest firmware from MacBook Pro via Firewire 800. AJA connects to playback monitor via HDMI.
    The AJA setup is fine. No other USB/Firewire devices involved. I just got off the phone with Aja tech support, they said that everything is set up correctly; we went through the entire control panel checklist. On top of that, I do get playback from FCP. So, the issue seems to be with After Effects…
    I have recently upgraded to Leopard. Prior to that, everything worked with the same setup that I’m using right now. Using AE CS3.
    Any ideas?
    Michael
    Michael Nikitin replied 17 years, 1 month ago 2 Members · 3 Replies
  • Gary Adcock
    August 4, 2009 at 9:39 pm
    [Michael Nikitin] “I’m having trouble with playback from AE. Perhaps someone will have pointers regarding what could be the issue. “
    Um…
    AE does not like working in Apple’s ProRes codec, what is your timeline set too?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Michael Nikitin
    August 4, 2009 at 9:45 pm
    I should have mentioned the video settings, of course. It’s DV-NTSC Quicktime at 29.97. That’s what the AJA settings are set to (525i29.97), and AE’s video playback settings as well. I also tried starting new comps and generating playback for a new color solid, for instance — to no avail.
  • Michael Nikitin
    August 4, 2009 at 10:36 pm
    Well… I fixed it. It took a complete uninstall/reinstall of Aja software, AND trashing AE preference files.
    I guess we’ll never find out what the problem was. 🙂
