Activity Forums Adobe After Effects Expressions Trouble with text margins and shape lining up. Using the sourceRectAtTime()
  • Trouble with text margins and shape lining up. Using the sourceRectAtTime()
    Posted by Josh Zimmerman on July 31, 2017 at 5:52 pm
    I am making a lower third template and can’t get this expression to work right.
    I have the shape layer I want to size(red square) to the text layer. The problem is when you add ascender letters(i.e. “y”). The shape layer sizes from the center and the text box just adjusts down. This makes an offset to where the red box’s position is and it doesn’t line up correctly.
    I have adjusted the anchor point and still changes nothing…
    Any thoughts?
    AE file HERE: 11551_wsf2017lowerthirds1.aep.zip
    x=20
    y=thisComp.layer("TEXT 2").sourceRectAtTime().height+20;
    [x,y]
    Josh Zimmerman replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
