Activity Forums Adobe After Effects Trouble with Shadows & Layer Styles
  • Trouble with Shadows & Layer Styles
    Posted by Richard Windsor on July 17, 2011 at 3:33 pm
    I have a comp that uses a camera and a few lights. I have all the shadows looking very nice, but when I add a layer style to any of the text, the shadow for that text disappears. The shadow is being cast by the lights I created and not from a preset. Is there anyway to get the shadow back but keep the layer style adjustment?
    Roland R. kahlenberg replied 15 years, 2 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    July 17, 2011 at 4:01 pm
    Layer Styles delimits 3D interaction with other layers. You should apply Layer Styles in a Precomp.
    In your current situation, simply select the Text Layer and Precompose it (in the precomp itself, the 3D switch isn’t important – it’s redundant since the Layer Style is applied to it –just so that you know). In the ‘parent/final/master’ comp, switch on the 3D switch and the Cast Shadows property and You’ll be back in business.
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Richard Windsor
    July 17, 2011 at 4:45 pm
    Thanks so much…worked great!!!!!
    July 17, 2011 at 11:51 pm
    You’re most welcome. Don’t forget NOT to click on the Collapse Transformation switch for the nested comp or you’ll be back to square 0.75. 😉
    Cheers
    RoRK
