Activity Forums Apple Final Cut Pro Legacy Trouble with Quicktime Export and DVD Burn: Pixelated/Artifacted Areas and Interlace Issues
  • Trouble with Quicktime Export and DVD Burn: Pixelated/Artifacted Areas and Interlace Issues
    Posted by Brad Kester on March 19, 2012 at 6:38 pm
    My video was shot on a Panasonic DVX. In Final Cut it shows these settings:
    Vid Rate: 29.97
    Frame Size: 720×480
    Compressor: DV/DVCPRO – NTSC
    Data Rate: 3.6 MB/sec
    Pixel Aspect: NTSC – CCIR 601
    Field Dominance: Lower (Even)
    When I export to Quicktime with the “Current Settings”, the video comes out stretched and has some artifacting (around right ear) and interlace issues (around the mouth). Looks like this:
    The only way I’ve been able to get the correct aspect ratio is to export to Quicktime using Custom Settings and changing Frame Size to a 4:3 ratio of 640×480. The rest of the settings are:
    Frame Size: 640×480
    Aspect Ration: NTSC (4:3)
    Pixel Aspect Ratio: NTSC – CCIR 601 / DV (720×480)
    Editing Timebase: 29.97
    Timecode Rate: Same As Editing Timebase
    Quality: 100%
    But the artifacting and interlacing issues remain. It looks like this:
    On all my past projects with the DVX, everything looks fine when I export to Quicktime. But I’ve heard that sometimes videos show up looking weird in Quicktime Player but are corrected when you burn to DVD. The DVD I made still has issues.
    How do I get rid of these pixelated areas? Why does my video come out looking stretched when I export iwth Current Settings? Am I downgrading the quality when I change the size settings? Any advice would be greatly appreciated. Thanks!
    BK
    Brad Elliott replied 14 years, 6 months ago 2 Members · 1 Reply
  • Brad Elliott
    March 19, 2012 at 7:53 pm
    Is your video supposed to be 16×9 or 4×3 letterboxed?
    Are the settings above for your sequence or the source clip?
    Click your sequence and then command+0(zero) to check if the anamorphic 16×9 box is checked. You should be able to export a 16×9 720×480 movie without any problems.
    I would always recommend editing in a sequence that matches your clip settings. Unless you have changed the preference FC should prompt you for this. If your source clip is supposed to be 16×9 confirm that anamorphic is checked in the anamorphic column. This could also be causing all of your problems.
