Activity › Forums › Adobe After Effects › Trouble with Point of Interest in Complex 3D Comp
  • Trouble with Point of Interest in Complex 3D Comp
    Posted by Eric Goldstein on July 9, 2007 at 2:20 pm
    I’m having trouble with the camera’s point of interest in a complex 3D comp. I’m generally using the camera’s x, y, z axis controls along with position to make my camera moves. I’ve been leaving point of interest alone. This has worked without a problem, but in a move in which the camera has to pan about 45 degrees, the point of interest is causing the camera to skew (which I’ve corrected using the other controls including orientation), but it’s making what should be relatively simple move complex and introducing unwanted movement. Also, I’m experiencing jumping in a far background element (a sky) during the same time that the camera is trying to skew – which I believe is traceable to the same point of interest problems.
    Any way to neutralize point of interest? Or is there a better way to work with it to avoid these problems?
    Thanks for your help,
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 19 years, 2 months ago 2 Members · 2 Replies
  • Darby Edelen
    July 9, 2007 at 2:37 pm
    You can disable the point of interest, which would probably be the way to go if you’re ignoring it already =) Just right click on your Camera layer and go to Transform > Auto-Orient and set it to ‘Off’ (these controls are also accessible in the Layer menu).
    Just another note: I like to use the camera tools to make my moves, you can cycle through these with the ‘c’ key. See how you feel about them.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Eric Goldstein
    July 9, 2007 at 2:40 pm
    Darby, Thanks very much for the help.
    Eric
    Eric Goldstein
    Los Angeles
