Activity Forums Blackmagic Design Trouble with output with Decklink/HDV
  • Trouble with output with Decklink/HDV
    Posted by Chris Smith on June 6, 2005 at 5:14 pm
    Okay, I ended up dumping in all the material regular HDV (not AIC). If I set the output to BM HD 1080 output I get black. If I set it to BM NTSC 8 bit, I get a picture on my monitor. However, although it plays real time on the FCP Canvas, I only get bad looking frames on my output when the playhead is stopped. It looks similar to the single field detting but that setting is off.
    I did what BM suggested and re-installed FCP 5 then the BM FCP 5 drivers last. No difference. Furthermore the SD I have always had in the machine (elements for my reel) won’t play out through the Monitor from the QT player. They did before. I went to check the ‘use QT legacy’ and it was already checked and greyed out. However, it will not play out the output.
    Any advice?
    G5 DP 2.0 / OSX 10.4.1 / QT 7.0.1 / BM Drivers 5.0 / FCP 5 / Decklink Xtreme
    Chris Smith
    https://www.sugarfilmproduction.com
    Chris Smith replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
