Activity › Forums › Adobe After Effects › TROUBLE WITH KEYING OUT! How do you get rid of one colour?
  • TROUBLE WITH KEYING OUT! How do you get rid of one colour?
    Posted by Daniel Haskett on April 20, 2005 at 6:52 pm
    Hi there
    Basically what I have done is created a walk cycle of someone in black and white, but because I want to loop it I have saved it as a movie with a blue background so that I can then get rid of the blue background once I import it again. I thought I could do this with colour key but it still leaves bits of blue around the edges of the man and if I put the tolerance up it takes away parts of the man. Surely there is a way to just eliminate a flat colour?
    Thanks in advance!
    Dan
    Daniel Haskett replied 21 years, 5 months ago 2 Members · 2 Replies
  • Steve Roberts
    April 20, 2005 at 8:07 pm
    Yeah, but it’s only a flat colour up to the edges of the next colour. Antialiasing blends the two colours, creating a smooth edge.
    You should have rendered with an alpha channel to get transparency. Render to a quicktime movie in the animation codec or to a series of TGA files, output module set to RGB+alpha, and millions of colours+.
    Steve
  • Daniel Haskett
    April 20, 2005 at 11:53 pm
    Cool thanks for your help, makes sense now.
    cheers
    dan
