Activity › Forums › Apple Final Cut Pro Legacy › Trouble with HD footage in DV timeline
  • Trouble with HD footage in DV timeline
    Posted by John Shand on May 11, 2010 at 12:40 pm
    I shot some footage in DV standard def and also some in HDSLR. Im editing in standard def on my timeline but when i imported the HD (720p) footage it looks pixelated is there a way to combat this?
    Rob Grauert replied 16 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 11, 2010 at 2:22 pm
    Have you transcoded the DSLR footage to ProRes? If not, that could be part or all of the problem unless the footage itself is pixelated (not uncommon from DSLR footage because it can’t deal very well with camera movement nor deal well with fast action.)
    Basically FCP doesn’t like H.264 files for editorial at all… and it only gets worse when you export sequences for delivery etc…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rob Grauert
    Do you have to render? SD doesn’t really look any good on a computer screen anyway. The pixels of SD video are non-square while the pixels on the computer screen ARE square. So SD just won’t really look to great. This is one of the reasons why you should only bother to judge your image on a broadcast monitor or decent TV at worst
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
