Trouble with HD footage audio sync
Hello,
I shot HD 1080i60 footage and captured it using iMovie. Then I “shared” it = Output is QT 1440X1080. Compression is Apple intermediate codec.I import this footage, and do some simple things in AE — a matte, a scale, a reposition to make the footage match other footage I’m using in a Final Cut Pro editing project.
I render the AE project out as a short, 5-second Quicktime movie using MPEG4 as the compression. When I play it in Quicktime player, the audio is faster than the video — it goes out of sync about half way through.
I try something else — I render it using HDV 1080i60 for compression. This time, the Quicktime movie looks and sounds fine in QT player. But when I import it into Final Cut and play it as a clip, it “chokes” on itself: the audio plays, but the video starts and stops, seemingly skipping frames.
Did I screw up on the what went in, or the what came out, or both?
