Trouble with footage….1920×1080 but should be 1440×1080
I’ve finally given in and “upgraded” to FCPX. Being a newbie, I am still struggling with this new version of FCP, so forgive me if I appear to not know what I am doing.
I have some footage provided by a client that I received on an external drive as Quicktime movies. They were simply copied over to the client’s drive and passed on to me. I imported the footage creating a new event without issue first. Looking at the video I realized the aspect ratio is a bit off. I checked the metadata and it says it is 1920×1080 right off the source, so there isn’t anything that changed it in FCPX. I attempted to change it by customizing the settings on a new project (sequence) but nothing doin’. After a while of stabbing at it with different settings, I decided to check it out in FCP7. When I set the sequence settings to 1440×1080 the aspect is correct, however I want to do this project in FCPX! I called the camera folks and they said it was shot on a Canon XHA1S in standard 4:3 and that they recorded to dv tape and the camera card. I have to be able to edit in the correct aspect ratio with all the titles and graphics I will be using in this video. Drive space is an issue so exporting it all from another program to transcode it (almost 400GB!) is not an option.
So my question is, is it me or them? Did they forget to change something in the camera settings for the record to card or should I be setting something in FCPX to import in the proper aspect ratio?? Can anyone help me shed some light here?
Thanks in advance!
MAC: 2 x 2.8 Quad Core Intel Xeon
Memory: 6GB 800 MHZ DDR2 FB-DIMM
Graphics: ATI Radeon HD 5770 1024 MB
OS: Mac OS X 10.8.3
Final Cut Pro 10.0.8
