Activity Forums VEGAS Pro Trouble with Excalibur 4 and Vegas 5
  • Trouble with Excalibur 4 and Vegas 5
    Posted by Mark F on May 4, 2005 at 10:40 am
    As I’m not 100% comfortable with Vegas 6, I’m still wanting to use Vegas 5. However, I know find Excalibur 4 no longer funtions as I get this error message when I enable:
    Exception: System.InvalidCastException: Specified cast is not valid.
    at PRExcal.Controls.EntryPoint.DynamicLoader.CreateEntryPoint(Type type)
    at PRExcal.Controls.EntryPoint.MainEntryPoint.StartEntryPoint(String typeName, String assemblyName, String settingsFile, Object[] entryArgs)
    Ideas?
    Edward Troxel replied 21 years, 4 months ago 2 Members · 3 Replies
  • Mark F
    May 4, 2005 at 10:47 am
    Update…I can get Excalibur 4 to work in Vegas 5 if I use the script from Vegas 6….did something go wrong in the install?
  • Mark F
    May 4, 2005 at 11:48 am
    Further Update and resolution….
    To get everything to work, I had to unistall Excalibur 4 for Vegas5 and reinstall….
  • Edward Troxel
    May 4, 2005 at 1:55 pm
    Yes, the solution is to uninstall Excalibur 4.0 and then install Excalibur 4.1. It appears you had “mix” of the two installed. Between 4.0 and 4.1 I had to change the names of a couple of files necessitating the uninstall requirement.
    Edward Troxel
    JETDV Scripts
