Activity › Forums › Avid Media Composer › Trouble with driver/graphics card
  • Trouble with driver/graphics card
    Posted by Obieobie on February 24, 2006 at 1:29 am
    I have an ATI Radeon EAX1600 Pro 256MB DDR2 PCI Express graphics card and an open GL hardware…I’ll admit, I’m not 100% up on everything, so I may be missing something simple. Is it that my card is not compatible with my driver?…where can I download a compatible one? When I try to play a clip in the preview monitor, or in the SEQ, it goes black. yet I hear audio. I can scroll through the clip, fast forward/rewind and see it, but not during actual playback…whats wrong?
    Thanks for anything you can offer.
    Mike
    Obieobie replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jon Zanone
    February 24, 2006 at 12:41 pm
    What version software are you using? What are your system specs? How much memory do you have?
    More input, please…
    IF you are on a PC, and AXP HD software, you might find this interesting (it’s from the Avid website)…
    Minimum PC System Specifications for Avid Xpress Pro
    Windows XP Professional with Service Pack 2
    QuickTime 7.0.3
    1 GB system memory minimum, 2 GB recommended for HD or high-stream count SD projects
    Dual or Single 2.4 GHz Xeon processor OR Pentium 4 1.6 GHz processor OR Pentium M 1.8 GHz processor (mobile configurations)
    Qualified graphics card (per model, as supported by system vendors)1
    Qualified IEEE-1394 FireWire port (integrated or add-in card2 ; Mojo is not supported on notebook systems with PCMCIA cards of any kind)
    40 GB or larger internal IDE drive3
    DVD-ROM or DVD+RW drive
    1 The following specific cards have been tested by Avid: NVidia QuadroFX 1400 PCI Express, NVidia QuadroFX 1300 PCI Express, Nvidia QuadroFX 1100 AGP 8X, NVidia QuadroFX 500 AGP 8X or NVidia Quadro4 980 XGL AGP 8X. Note: Although supported, use of the NVIDIA Quadro 4 980 XGL in a dual-monitor configuration may result in performance degradation during tasks such as scratch removal, auto color correction, or general color correction when the safe color warnings are enabled, or using the eyedropper to select colors in Effect Mode. Single monitor systems with an NVIDIA Quadra 4 980 XGL perform properly.
    It appears your card isn’t qualified…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Obieobie
    February 24, 2006 at 6:56 pm
    Here is what the system is. Let me know if you have any advice based on this. The version of Avid I’m using is Xpress Pro 4.6
    Thanks again
    Intel Pentium 4 3.0Ghz s775 Processor, 2mb Cache
    Asus P5GD1-VM Motherboard – s775, LAN, SND, PCI-Ex, S-ATA
    2GB PC3200 DDR Ram, Dual Channel (2 x 1GB Pieces)
    Asus ATi Radeon x1600 Video Card – PCI-Ex, 256MB DDR
    Western Digital 160GB S-ATA Harddrive
    Additional 80GB S-ATA Hard Drive
    LiteOn 16x DVD-+RW EIDE Drive
    1.44mb Floppy Drive
    Logitech Z-4 2.1 System Speakers
    ATX 450Watt Power Supply
    Acer 1916SB 19″ LCD Monitor
    Additional Acer 1916SB 19″ LCD Monitor
