Activity Forums Maxon Cinema 4D Trouble with coordinate entry
  • Trouble with coordinate entry
    Posted by Jack Cook on June 8, 2016 at 10:01 pm
    I’m using Cinema ver. 16, on Mac OS 10.11.4. Behavior of the Coordinates panel has changed lately. When I choose the Scale option from the menu under Scale and put in a value of any kind the number always reverts back to 1 as soon as I type it. I am not able to scale objects numerically as I was before. I can choose the Scale tool, however, and drag and scale objects up and down that way, but I like to be able to use the numerical Scale option. This has been happening for a couple of weeks now. I also have the same problem using the numerical rotation in the HPB boxes – it simply won’t take any numbers, yet I can rotate object with the Rotate tool, and it reflects in the numbers in the boxes. I can’t figure out what has changed to cause this to happen. Anyone have any ideas?
    thanks,
    Jack
    Jack Cook replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
