Activity Forums Apple Final Cut Pro Legacy trouble with batch capture
  • trouble with batch capture
    Posted by Chris Gallaway on February 22, 2011 at 4:43 pm
    Hi folks,
    I recently had the misfortune of inadvertently wiping a hard drive, but thankfully I had the project file saved elsewhere. I’m no in the process of going back to the original project and trying to re-capture (using batch capture) all of the old media. I’ve separated all the video files into bins according to their source tapes. I then try to do a batch capture for each tape, but the process is not running smoothly. The capture dialogue continues to kick out and claim that it cannot find the timecode. It will successfully capture about half of the clips in the bin, but the other half it will miss. Sometime, on a second pass, it will pick up clips that it missed before.
    I’m guessing there is a problem with my device control presets. The original tapes were recorded in Canon’s 24F framerate on my XH-A1, and I’m using the same camera to capture now. My capture preset is set to “HDV,” and I’ve tried many different device control presents (HDV Firewire, HDV Firewire 25fps, HDV Firewire NDF), but they all have the same problem. It will successfully capture a few clips, then bog down and kick out of the capture process, claiming it can’t locate the timecode. I would sure appreciate any insight that you folks could offer. I’m at a loss here.
    Many thanks to you,
    Chris Gallaway
    Chris Gallaway replied 15 years, 6 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    February 23, 2011 at 3:11 am
    HDV is really twitchy for it’s timecode. And if you’ve turned on/off the camera during shooting? Even worse. No real good/easy news here.
    At least one workflow suggestion – you can search for all the reels across the project and batch capture from the find window. This at least will make sure you’re limited to the one tape.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Chris Gallaway
    February 23, 2011 at 3:50 pm
    Ha, ha. Well, that’s not exactly good news, but it’s nice to know that I’m not causing this problem. Thanks for the help, Jeff.
    -CG
