Activity Forums Adobe Encore DVD trouble with audio in slideshows
  • trouble with audio in slideshows
    Posted by Ollie Parke on May 16, 2006 at 3:59 am
    I am using Encore DVD 1.5. I’m pretty knew to the programs so i’m having troubles, which are probably glaringly obvious to the experienced user. Anyway, I have created music tracks with fades etc in Premiere 1.5 and output as .WAV files. I then import as asset, drag and drop into my slideshow timelines. It plays back fine in preview within the program. I make sure the .wav is untranscoded also. When i burn the final dvd the audio skips a beat between every photo change. This happens with or without chapter points on the slideshow. Why is this happening and how is it fixed? I can’t find any advice in the literature i have so i’m hoping someone out there can help me out.
    Thanks.
    Joe Bowden replied 20 years, 4 months ago 2 Members · 5 Replies
  • Joe Bowden
    May 16, 2006 at 3:51 pm
    Are you using an AVI from PPro for the stills?
  • Ollie Parke
    May 16, 2006 at 11:54 pm
    No the stills are all imported Jpegs, inserted in the standard way. The problem happens in the photo transitions. this happens with or without chapter point between each photo.
  • Joe Bowden
    May 17, 2006 at 2:44 am
    Where do you see the problem- in a set top DVD player? If so, have you tried it in another player?
    Are you transcoding Dolby Digital or MPEG-1 Layer II?
  • Ollie Parke
    May 17, 2006 at 3:03 am
    Yes the problem is found in a set-top DVD player and I’ve tried several, with the same result. i’m transcoding in MPEG 1 Layer II.
  • Joe Bowden
    May 17, 2006 at 4:12 am
    I would recommend that you encode your audio to Dolby Digital instead. Let us know if that works for you.
