Activity › Forums › Apple Motion › Trouble with alpha using Illustrator files
  • Trouble with alpha using Illustrator files
    Posted by David Eells on December 3, 2010 at 1:59 pm
    I often use Illustrator files in Motion. Most of the time I have no problem, but occasionally the Alpha dropdown in the Media tab in the Inspector is not present for a particular graphic. If I open the graphic in Photoshop and specifically create one and resave and reimport, still no luck. This has happened even when the parent graphic worked fine and I have made a sub-graphic, the sub-graphic will lose the ability to choose or use an alpha channel.
    This is weird, because even .aif files give you this option. But on certain random graphics, the first parameter in the list is pixel aspect ratio rather than alpha type.
    Anyone else ever see this, and more importantly, know how to fix it?
    David Eells replied 15 years, 9 months ago 1 Member · 1 Reply
  • David Eells
    December 17, 2010 at 2:40 pm
    I scratched my head for a while and figured it out., and the answer is: Operator Error. Motion doesn’t show choices for alpha in the Media Tab for illustrator files, but it stil recognizes the alpha.
