Activity › Forums › VEGAS Pro › Trouble w/ Quicktime Update for V8
  • Trouble w/ Quicktime Update for V8
    Posted by John Magee on September 15, 2007 at 4:45 pm
    The quicktime installer I downloaded from apple hangs up in the middle and says something like “the feature you are trying to install is on a disc (somewhere)please insert quicktime disc”. It seems to want “quicktime.msi”. I tried downloading again, closing all apps, but same problem.
    John Magee replied 19 years ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    September 15, 2007 at 11:04 pm
    sounds like something on your system is corrupting the download from Apple. Are you running antivirus?
    Try downloading again, be sure you’re getting it stored/tranferred completely before installing?
  • John Magee
    September 16, 2007 at 7:11 pm
    Thanks, but antivirus is off. Well, there is another error message after I close the first one – it says “could not uninstall older version of quicktime”. So I tried to do that myself, but nope, the windows uninstall doesn’t respond. …maybe if someone knows how to uninstall this thing “manually” it might work?
    Thanks.
  • John Magee
    September 16, 2007 at 9:37 pm
    I found a solution: Microsoft has a utility called “Windows Install Cleanup”. Since the uninstall programs for itunes and quicktime are screwed up, you may need this:
    https://support.microsoft.com/default.aspx?scid=kb;en-us;290301
    John Magee
