Activity › Forums › Apple Final Cut Pro Legacy › Trouble w/ FCP 5.1 and new 17″ MacBook Pro
  • Trouble w/ FCP 5.1 and new 17″ MacBook Pro
    Posted by Jeff Jeffares on September 1, 2006 at 3:57 pm
    When I open FCP 5.1 and try to open a sequence, I get a dialog box that says, “Codec not found. You may be using a compression type without the corresponding hardware card.”
    Any suggestions?
    Jeff
    Jeff Jeffares replied 20 years, 1 month ago 2 Members · 2 Replies
  • Todd Reid
    September 1, 2006 at 4:01 pm
    What is your sequence preset?
    Change to DV NTSC 48kHz and see if that helps.
  • Jeff Jeffares
    September 1, 2006 at 4:04 pm
    Thanks, that took care of it!!
    JJ
