Trouble syncing two different audio sources.
Hi, I’m using the newest version of Premiere CC and am having issues combining a separate audio source to camera audio. The camera is recording AVCHD 1080p with 48000kbps (compressed) audio. We are combining the camera audio with a separate microphone feed from a speaker’s lavalier microphone. This audio is also recorded at 48000kbps but in AIFF format.
In premiere, all goes well when matching up the two sources in the beginning, but the two gradually separate from each other as the timeline moves on. For a 3 hour event by the end of the timeline, the two sources are almost a full second out of sync. What could be causing this?
At first we thought it was because of a different sample rate, but the same thing happened when we matched rates. Could it be a compression issue? Any advice is greatly appreciated.Thanks!
