Activity › Forums › Maxon Cinema 4D › Trouble selecting one polygon when its in a group/fracture!
  • Trouble selecting one polygon when its in a group/fracture!
    Posted by Marcin Koziel on August 16, 2012 at 8:10 pm
    So I have a fracture of polygons and I want to select one on the perspective view but if I click on that one polygon, the whole group/fracture will be selected.
    The thing is I cannot just go through the polygons in the object(s) list because there are 512 of them. I need to select it though the perspective view.
    I would really appreciate anyone’s help!
    Marcin Koziel replied 14 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 17, 2012 at 12:43 am
    if you disconnected the polys from each other then made the Fracture editable all the polys are objects now so you won’t be able to select them in poly mode until you select the object so select what you need in model/object mode first.
  • Marcin Koziel
    August 17, 2012 at 4:28 am
    yes, I figured out just now you have the option to switch to Object instead of Model. Thanks
