Activity Forums Adobe After Effects trouble scrolling animation
  • trouble scrolling animation
    Posted by Ricardas Tube on April 27, 2007 at 8:24 pm
    Hi guys!
    I’ve got a weird problem :
    it is extremely hard to scroll my files rendered in animation.
    I’m on G5 dual core.Although i get no problems while scrolling
    7 gb mpeg 2 files in MPEG Streamclip and other apps, i face
    difficulties in scroling 500mb files in After Effects.
    Any ideas?
    Kevin Camp replied 19 years, 4 months ago 3 Members · 5 Replies
  • Iancorey
    April 27, 2007 at 8:37 pm
    It’s HARD to scroll them? Keyframe-bottom, move, keyframe-top is hard?
    I think you mean something different than HARD. What is it that you mean?
  • Ricardas Tube
    April 27, 2007 at 8:57 pm
    Hi!
    Well, sorry for my English…
    What i mean is that i have difficulties in moving current time
    indicator- it is very slow.
  • Kevin Camp
    April 27, 2007 at 9:27 pm
    when using codcs with temporal compression in ae, you will force ae to work very hard to create the frames between the compression keyframes.
    you will not experience these problems if you use codecs that do not use or have the option to disable interframe or temporal compression.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Ricardas Tube
    April 27, 2007 at 9:38 pm
    Thanks Mate!
    I’ll try to sort it out this way…
    Cheers!
  • Kevin Camp
    April 27, 2007 at 9:47 pm
    image sequences are good place to start and are compatible in almost every system, so you should be able to export one from other software easily. image sequences, by nature, can not use interframe compression.
    Kevin Camp
