Activity Forums Adobe Illustrator Trouble Removing cut lines!
  • Trouble Removing cut lines!
    Posted by Katie Jarvis on August 6, 2009 at 7:44 pm
    I have Adobe Illustrator CS3 and i use a vinyl cutter with the software.
    When creating layers i expand the path of the original text and place the expanded behind the text to create a new layer. However, when creating the new layer, the cut lines of the text bubble together, making it impossible to cut. I have been getting rid of these cut lines by hand forever, and it’s just too time consuming. I want the second layer to be a solid outline, but its impossible with all the cut lines. There has to be a better way!
    Please help?
    Katie
    Vincent Rosati replied 17 years, 1 month ago 2 Members · 1 Reply
  • Vincent Rosati
    August 8, 2009 at 4:05 pm
    I’m not sure I exactly understand what you are describing.
    You outline the text (Type/Create Outlines), and place the outlined text in a layer that is beneath the live text.
    I’m not sure what you mean by ‘bubble together’
    Are you using strokes on your text? Perhaps you need to Object/Expand, before outlining – or after.
    Your cutter may also require to save your AI file to an earlier version. Maybe try saving as an EPS.
    Just a few thoughts.
    Vince
    *Please remember to Rate our replies and check Solution if solved. Also, we do this out of love and fun, so its always nice to recieve a Please and Thank You! 🙂
