Activity › Forums › Adobe Premiere Pro › Trouble playing DPX sequences
  • Trouble playing DPX sequences
    Posted by Bret Hampton on September 6, 2017 at 5:46 pm
    Hi gang
    My computer plays almost everything at full resolution with Mercury playback except for dpx sequences. I prefer full rez as I do film restoration and anything less obscures the very things I need to fix.
    HP Z800 dual Xeon processors 6 cores each
    24g ram
    SSD boot drive
    NVIDIA GTX 870 GPU
    G-Tech G Speed ES w/their controller
    PP CC current version.
    Bret Hampton replied 9 years ago 2 Members · 4 Replies
  • Tero Ahlfors
    September 6, 2017 at 5:58 pm
    With DPX sequences your storage media needs to be fast. How big DPX frames are you trying to run at what frame rate? How fast is your storage?
  • Bret Hampton
    September 6, 2017 at 8:58 pm
    Hi Tero
    Am using G Tech Gspeed es in Raid 0, all Enterprise class 7200 rpm drives. DPX files are 2336×1752 16m each at 23.98. (These are 4×3/1.33 film scans of a 1928 movie.
  • Tero Ahlfors
    September 7, 2017 at 3:56 am
    [Bret Hampton] “Am using G Tech Gspeed es in Raid 0, all Enterprise class 7200 rpm drives.”
    But how fast is it? You would need at least 400 MB/s and the official specs say that it can run up to 252 MB/s. Which is not enough.
  • Bret Hampton
    September 7, 2017 at 3:24 pm
    Thanks Tero
    That was the information I needed but couldn’t remember. As configured my system isn’t fast enough. Do you play dpx files? What drive setup could handle this?
