Activity › Forums › Adobe After Effects › trouble making displacement map /is it a gradient unsure
Posted by Chris Smith on September 2, 2008 at 2:35 pmhi im having trouble in createing a gradient in after effects cant find it any were
used new solid resized it to fit how do i colour the solid to a gradient i cant find the tool, its for a displacemnt map
https://uk.youtube.com/watch?v=TUgJUMfSHl8
heres the link i think that how it was created
Darby Edelen replied 18 years ago 3 Members · 5 Replies -
Chris Smith
September 2, 2008 at 3:29 pmive have two layers flag layer, solid layer
ive used a blur which has given a black to white gradient on a solid
still cant seem to get the flag to crease, when i put the displace on the flag layer,it seems to destroy the flag vertical or horizontal
please can any 1 help
Mike Clasby
September 2, 2008 at 3:56 pmMost folks use the effect, Ramp. That layer with Ramp needs to be precomposed (Layer>Precompose) to make the displacement map work.
On the main AE page, here:
https://forums.creativecow.net/forum/adobeaftereffects
Click on Aharon’s head and scroll down to almost the bottom (long scroll, lots of tuts by Aharon) to find his three part tutorials on displacement maps, and all things displacement will be explained… in detail.
Darby Edelen
September 2, 2008 at 6:00 pmHere are the ‘gotchas’ that I’m aware of for displacement maps:
1) Make sure that you have the displacement map effect linked to the correct layer.
2) Make sure that if your solid has effects applied, it is pre-composed (with all effects inside the pre-comp) so that the effects are forced to render BEFORE the displacement map effect tries to access the solid.
Darby Edelen
NVIDIA
Santa Clara, CA -
Chris Smith
September 3, 2008 at 11:58 amin the timline comp ive made 1 layer white solid scaled it down applied a fast blur so its a rectangle in shape,moved its position horizontal on x axis….this going to be the displacement map and do i place the displacement map on the flag or on the solid …..
do i precompose the white solid now …..
then add the flag to timeline comp
i tried to see the tutorials on the podcast unknown file type
Darby Edelen
September 3, 2008 at 9:33 pmYou must pre-compose the white solid and be sure to ‘move all attributes.’ Then apply the displacement map effect to the flag layer.
Darby Edelen
NVIDIA
Santa Clara, CA
