Activity › Forums › Adobe After Effects › Trouble making a trail of dots.
  • Mathew Fuller
    August 12, 2013 at 7:20 pm
    Your link doesn’t work… but a trail of dots can be made quite easily in about a hundred different ways.
    Particular
    3D Stroke
    Masks
    Take your pick.
    My Work:
    https://www.morecompletefx.com
  • Joseph W. bourke
    August 12, 2013 at 7:23 pm
    Dom –
    I generally have very good luck using Type on a Path. It’s a simple matter to choose the typeface which gives you the dot shape you want (square or round, generally), then just type a bunch of Periods. You can then select and space them however you want, and then animate them along the path if need be (I couldn’t get at your example). Here’s a rundown of text on a path, in case you’re not familiar with it:
    https://ae.tutsplus.com/tutorials/motion-graphics/animating-text-along-a-path-in-after-effects-ae-basix/
    This has always been the simplest solution for me, and it gives me a huge degree of control.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Dom Constantine
    August 12, 2013 at 7:38 pm
    I knew linking a facebook video was a bad idea. Here’s a fixed link: https://www.youtube.com/watch?v=h6gO6w7jXJA&feature=youtu.be
  • Dom Constantine
    August 12, 2013 at 7:40 pm
    Thank you! I will try the type on a path versus using the mask path which is providing to be a headache for what I’m going for.
  • Ridley Walker
    August 12, 2013 at 8:54 pm
    Or you could use shape layers with dashed lines round joins and animate the offset.
    6396_dots.aep.zip
