Activity › Forums › Apple Final Cut Pro Legacy › Trouble keying Photoshop Targas in Final Cut
  • Trouble keying Photoshop Targas in Final Cut
    Posted by Dan Skinner on July 8, 2006 at 5:28 pm
    I am having trouble keying Photoshop Targa files (with alpha) in Final Cut. When the keyed graphic plays over video it makes the video brighter. After the graphic goes off the screen the video returns to normal. I have tried using dissolves, cuts, and opacity to transition the graphic on and off. I get the same result. Any ideas as to what is causing this?
    Dan Skinner replied 20 years, 2 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    July 8, 2006 at 7:34 pm
    Yeop… save the tga files in the RGB colorspace. I’ll bet they are in CMYK…
    Jerry
  • Dan Skinner
    July 8, 2006 at 9:25 pm
    The graphics are in RGB mode.
  • John Calhoun
    July 10, 2006 at 1:30 pm
    What’s your process for creating the alpha?
  • Dan Skinner
    July 11, 2006 at 12:32 pm
    In Photoshop I merge my layers and Select Layer Transparecny. Then I go to the channels and create an alpha channel. I then fill in the selection with white. Everything else in the black is what will get keyed out. The I select the RGB channels and save out as Targa with alpha.
