Activity › Forums › Apple Final Cut Pro Legacy › Trouble importing XML file for subtitles
  • Trouble importing XML file for subtitles
    Posted by Zach Clark on August 18, 2008 at 4:17 pm
    Hello, I’m having issues importing an XML file for subtitle purposes. Upon bringing the XML nto final cut, I get the following error:
    ERROR: Critical errors aborted the processing an XML document. Would you like to see a log of those errors now?
    The log looks like this:
    Mon, Aug 18, 2008, 12:02 PM – Errors Found Importing test.xml
    sequence(SwiftSubtitles) – : Unknown element encountered.( line 1 )
    sequence:media:video:track:clipitem(test0001.png) – : Unknown element encountered.( line 1 )
    sequence:media:video:track:clipitem:file(test0001.png) – : Unknown element encountered.( line 1 )
    sequence:media:video:track:clipitem:file:media:video(test0001.png) – : Unknown element encountered.( line 1 )
    : Required element duration not found for definition
    The file was created by our subtitle guy. Looking at the file in text edit, I can see all the file paths for the .pngs are routed to his My Documents folder on his PC. I tried changing the file path to:
    file:Users/zach/Desktop/test/test0001.png
    but that didn’t seem to do the trick.
    Am I entering in the file path info incorrectly? Once I know the correct file path, is it easy enough to just tell our subtitler to re-enter that on his end, or do I have to re-enter this manually for every single subtitle?
    Thanks so much!
    Zach Clark replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
