Activity Forums Adobe Premiere Pro Trouble Importing – AVCHD and MTS
  • Trouble Importing – AVCHD and MTS
    Posted by Lauren Kaiser on November 30, 2017 at 5:22 pm
    I could really use some help.
    I’ve shot video onto a memory card, I pop the memory card into my computer (using an iMac) and normally what I do is click on the memory card>private>AVCHD. Now typically when I click on AVCHD it brings up thumbnails, I double click the thumbnails, they open in QuickTime and I click file save and I save the files to my computer before importing to premiere and that has worked great for me until today…
    Today once I got to the last clip I needed to save it said operation could not be completed. So I went back and this time I did a right click on AVCHD, show package contents, right click on BDMV, Stream. When I do this I see all of the MTS files and the same clip seems to save just fine as a MTS file.
    WHY? I’m very confused. I don’t know why my normal way didn’t work. And to be honest, I don’t understand the difference between the two things I tried, what a MTS file really is and how that’s different than saving it through quick time? Is there a benefit of doing it one way over the other? If anyone can help me make sense of it I’d appreciate it.
    Lauren
    Ann Bens replied 8 years, 9 months ago 4 Members · 6 Replies
  • Jon Doughtie
    November 30, 2017 at 6:05 pm
    You don’t mention what version of the Adobe suite you are using, but I think you are making this way too hard for yourself.
    If you edit using Premiere Pro, simply use the Media Browser within the application to import your footage to your bins. Media Browser is familiar with the storage methods used by various manufacturers, and can go straight to the media without you hunting around at all.
    My workflow is to copy the original media with all the original folder and files structure into folders within my project structure and import from there.
    MTS stands for MPEG Transport Stream. It is generally MPEG-2 or AVCHD compressed video optimized for delivery over IP (internet protocol). It is popular in many cameras due to small file size relative to overall video quality.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Lauren Kaiser
    November 30, 2017 at 7:54 pm
    The issue isn’t really with adobe, it really more about file types and the fact I need to save the files to my computer before working in adobe. The trouble is simply from getting the files from the SD card to the computer itself.
    What you said about AVCHD vs. MTS helps a lot though. If I understand correctly, are the MTS files better quality than the AVCHD files?
  • Lauren Kaiser
    November 30, 2017 at 7:57 pm
    Thank you for your response! I’ll definitely give using the media browser a shot. However I still face the issue of getting the footage off the SD cards, thats the real issue. I need those files to be saved onto my computer before working in premiere.
  • Ricky Barrow
    November 30, 2017 at 8:20 pm
    Just copy the folder structure from the card to your computer – drag and drop to where you want them – unless I’m missing something?
    Ricky
  • Lauren Kaiser
    November 30, 2017 at 10:30 pm
    Yes, when I double click on the AVCHD in order to see the files, I do see thumbnails, but you can’t drag and drop them. You must open the files individually with QuickTime and save them. However, if I go the other route, once I go through the steps of getting to the MTS files I can drag and drop those. Which brings me back to one of my original questions: What’s the difference between the two ways of doing things? Are the MTS files as good as or better than the quick time files.
  • Ann Bens
    December 1, 2017 at 9:26 pm
    You dont need the quicktime files.
    Put your card in a card reader, open en copy the entire card to hdd.
    The use the Media Browser, navigat to the BDMV file on your computer and click on STREAM to import the mts files.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
